2wd saph piston slap
does it only slap when cold as they all do. the 4wd had an offset gudgeon pin that reduced the slap quite a bit. these pistons are lower compression depends on the depth of the head ie has it been skimmed. PJ motorsport can advise you.
Russ Payne
Sep 25, 2015 08:29 PM
timsrs
22
Sep 24, 2015 08:14 PM
dojj
28
Sep 11, 2015 10:00 PM
