Well took off and cleaned my ISCV but.... *HELP ME TECHIES!*
Old Apr 27, 2005 | 07:42 AM
BlueSmoke's Avatar
BlueSmoke
PassionFord's crazy fool!
Default Well took off and cleaned my ISCV but.... *HELP ME TECHIES!*
althought it's better, it's still not 100% right. It cut out on me in heavy motorway traffic this morning and it also started bunnyhopping like it was struggling to go one time when I tried to change lanes.
I guess this must mean a new ISCV for the car? Can't believe there's more money to be spent on the bloody thing......
How much will it set me back from Ford and do you get both parts?
Old Apr 27, 2005 | 08:03 AM
Ryan's Avatar
Ryan
Think there about £80-90
Old Apr 27, 2005 | 08:20 AM
Alvyn's Avatar
Alvyn
Default Re: Well I took off and cleaned my ISCV but....
How much will it set me back from Ford and do you get both parts?[/quote]
you DONT want to be buying one from Fords over £200 from them but as above between £70-£90 from Burtons,Pj etc!
Old Apr 27, 2005 | 08:22 AM
BlueSmoke's Avatar
BlueSmoke
I dunno where to go in Leeds then...... Maybe Motosave?
Martyn's Avatar
Martyn
I took mine off and turned up the idle speed
Old Apr 27, 2005 | 08:23 AM
R4N SS's Avatar
R4N SS
why not phone burton or PJ and get them to post it
Old Apr 27, 2005 | 08:32 AM
BlueSmoke's Avatar
BlueSmoke
Want it done by tomorrow..... meant to be going on a trip at the weekend. Drove it to work today, it wasn't terrible but I don't wanna be worried while I'm driving.
Martyn, how do I turn up the idle speed?
And just to confirm I took off the right part(!!), it was in two parts, one end with an electrical plug in it, cylindrical shape, and the other part had 3 holes on the back.... that was right, wasn't it?
Old Apr 27, 2005 | 08:37 AM
Martyn's Avatar
Martyn
What car is it mate?
Old Apr 27, 2005 | 08:40 AM
BlueSmoke's Avatar
BlueSmoke
'94 Zetec 1800 (Escort).
Old Apr 27, 2005 | 08:43 AM
Graceland's Avatar
Graceland
Team HOTHOT!
go to wells and moorhouse breakers in Meltham - only 2 quid last time i bought one - and if it doesnt work, swap it for another, and another and another
Old Apr 27, 2005 | 08:51 AM
BlueSmoke's Avatar
BlueSmoke
Paul, I'm at work all day every day so no chance of going however feel free to go on my behalf! I could always come and collect it from you after work.
I know you're way too much of a lazy shit to do that for me tho
Martyn, I'd like to try turning up the idle speed.... how do I do it and how much should I do it?
Old Apr 27, 2005 | 08:59 AM
BlueSmoke's Avatar
BlueSmoke
Old Apr 27, 2005 | 09:11 AM
BlueSmoke's Avatar
BlueSmoke
Come on guys, I've got a desperation for this information!
Old Apr 27, 2005 | 10:00 AM
BlueSmoke's Avatar
BlueSmoke
Come on guys, where have you all gone? I need your knowledge before I end up going to Ford's at lunchtime and paying over the odds!
Old Apr 27, 2005 | 10:56 AM
BlueSmoke's Avatar
BlueSmoke
Old Apr 27, 2005 | 11:25 AM
GUZZLER's Avatar
GUZZLER
a common iscv for a 1.8 escort is finnis, 6617 092, £34.05 +vat.
if this is the same as your one, then the number on your unit should be,
928F 9F715 AE
Old Apr 27, 2005 | 11:38 AM
BlueSmoke's Avatar
BlueSmoke
Cheers Guzzler, I will try and pick one up on my lunch hour then and fit it this evening. I just hope the iscv IS the cause of the problem here.....
Old Apr 27, 2005 | 11:43 AM
GUZZLER's Avatar
GUZZLER
no worries, best of luck with it
Old Apr 27, 2005 | 11:52 AM
foreigneRS's Avatar
foreigneRS
Testing the future
unlikely to be an iscv problem. the iscv shouldn't really come into play once the engine is warmed up, unless the engine is loaded. more likely to be a vacuum leak or sensor fault or something.
Old Apr 27, 2005 | 11:58 AM
BlueSmoke's Avatar
BlueSmoke
Oh no.... conflicting reports! That's the last thing I needed..... what would I have to do to sort that out? And how can I confirm what the problem actually is? To be honest tho, the engine seems to be fine once I've been up and running a while and it seems to happen only rarely then.
Does that help?
Old Apr 27, 2005 | 02:09 PM
foreigneRS's Avatar
foreigneRS
Testing the future
well the whole point of the iscv is to increase the idle speed when cold for smooth running, or to maintain it when hot and under load at idle (e.g. rad fan on and taking a lot of electrical power, or power steering sapping power). apart from those times, it should not come into play.
what are your symptoms exactly? i may have mis-interpreted your first post, i didn't notice the heavy trafic bit and just saw the motorway bit.
if it is iscv, they can normally just e cleaned up with carb cleaner and lubed up to work again.
as cars get older, the throttle assy gets worn and can cause idle problems. you should set your base idle speed first with the engine hot and all electrical things off and with the iscv disconnected. have you done that? could be a screw that controls a needle valve to bypass the throttle plate, or could be a screw to set the gap around the throttle plate (not familiar with your engine).
Old Apr 27, 2005 | 02:22 PM
BlueSmoke's Avatar
BlueSmoke
Not had my haynes manual arrive yet so I have no idea how to adjust my idle speed..... I've just bought a new iscv on my lunch hour but if I can sort it without that I'll just take it back.
How exactly do you set idle speed on the Zetec, anyone?
My exact symptoms here are that when I start up the car it seems fine in neutral, with or without electrical stuff on, but then as soon as I put it in first or reverse, it drops the revs, spluttering all the way down to cutting out.
If I've got the car out driving and I slow down at a junction it dies sometimes, and like this morning when I was doing a slow 1st and 2nd gear crawl in traffic it cut out. At one point there was a bit of space to move into the next lane and the car just started jerking when I put my foot down to move into it.
When it's warmed up and been running for a good while it doesn't seem to happen much, but it does still happen occaisionally. I cleaned out my iscv last night so if it is that, it's better to just replace it I think.
Does that help?
Old Apr 27, 2005 | 02:47 PM
BlueSmoke's Avatar
BlueSmoke
Old Apr 27, 2005 | 02:56 PM
foreigneRS's Avatar
foreigneRS
Testing the future
did you have you foot on the throttle at all? if so, the iscv should not be in play.
jerking when trying to accelerate does not indicate an iscv fault to me.
Old Apr 27, 2005 | 03:02 PM
BlueSmoke's Avatar
BlueSmoke
I can't honestly remember if I had my foot on the throttle or not at the time now.... I was giving it a little throttle and then rolling with brake and clutch a lot of the way tho.
When I said it jerked when trying to accellerate I should add that this happens when it's already dying and I put my foot down.
Old Apr 27, 2005 | 03:26 PM
foreigneRS's Avatar
foreigneRS
Testing the future
sounds like something other than iscv to me. fit your new one and see if it helps, otherwise i would start to look for vacuum leaks (air is maybe getting into the engine from somewhere and the ecu doesn't know about it so it runs lean and runs like shit.
let us know how you get on. have to go now.
Old Apr 27, 2005 | 03:32 PM
BlueSmoke's Avatar
BlueSmoke
OK mate cheers, but can someone tell me how to search for an air leak if it comes to it?
Old Apr 28, 2005 | 10:58 AM
foreigneRS's Avatar
foreigneRS
Testing the future
no luck with the iscv then? can't say as i'm surprised. i'm not saying it is defintely a leak, but it sounds like one. but it could also be a sensor fault.
to look for an air leak, get some bradex easy start or other volatile spray. spray it around various joints on the inlet side and if you hear the revs rise, then you know that it has been sucked in, improved the combustion and made the engine run better.
aother way is to pressurise the inlet system and search for it, but that's difficult at home.
Old Apr 28, 2005 | 01:02 PM
BlueSmoke's Avatar
BlueSmoke
Nah no luck mate. I'm gutted, I really hoped it would sort it. Where do I get bradex? I might just have to take it into a garage and pay out even more money I can't afford ont he damn thing....
chowfornow
14
Jan 5, 2019 09:01 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
fordrallycar
Sep 30, 2015 07:57 PM
RSmark84
Sep 13, 2015 01:29 PM
