ERST S2 Oil Pressure
Old Apr 26, 2005 | 01:08 PM
Blade Blower's Avatar
Blade Blower
Default ERST S2 Oil Pressure
Hi there
Just installed an oil pressure gauge & oil temp gauge in my erst s2 89 and just wondered what the correct pressures should be?
These are the results i'm getting. Could anyone tell me if these are normal
Car Cold
20psi @ 900rpm / 48psi @ 3000-4000rpm
Car Hot
12psi @ 900rpm / 40psi @ 3000-4000rpm
Also when the car is started from cold it takes around 2-3 secs for the pressure light to drop out.
Is it worth fitting a high pressure pump & what would the differance in pressures be??
Many Thanks
Old Apr 27, 2005 | 12:16 PM
davidnormanuk's Avatar
davidnormanuk
What grade oil are you using?
Dave
SMILER258
Sep 28, 2015 09:04 AM
