HEATED SEAT/FUEL CONTROLLER IN FUSE BOX
Old Apr 25, 2005 | 11:15 AM
davidnormanuk's Avatar
davidnormanuk
Default HEATED SEAT/FUEL CONTROLLER IN FUSE BOX
Some interesting info for you. Went to Well Lanes on Friday to get setup properly and it turns out my car wasn't fuelling properly due to the black ECU being faulty.
He tested this by pulling the fuse out of the heated seat part in the fuse box and lightly touching the 2 terminals with the fuse. Apparently this shoudl make the car judder slightly. If it doesn't then the fuel ECU isn't working.
Put my spare fuel ECU on and sure enough doing the trick with the fuse caused the car to judder slightly.
Just thought I'd mention it on here as alot of people don't seem to know about this.
Dave
Old Apr 25, 2005 | 12:03 PM
sufsRS's Avatar
sufsRS
cool, so wot are well lane like then i only live up the road
Old Apr 25, 2005 | 02:15 PM
davidnormanuk
They are spot on. The bloke took me through what he was doing and why and what I could do to correct the problems I had. Following his advice I am now running high boost without any problems. Best Ł85.00 I've spent.
Dave
Old Apr 25, 2005 | 07:51 PM
DazC's Avatar
DazC
The heated seat fuse is the fuse for the whole fueling system bar the fuel pump mate.
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Kam B
Sep 24, 2015 10:40 AM
cossie09
Sep 10, 2015 06:56 PM
markk
Sep 9, 2015 08:11 AM
