rst crank sensor
Old Apr 24, 2005 | 11:39 AM
monty's Avatar
monty
Default rst crank sensor
im in the middle of doing a efi conversion to a s2 turbo engine and came accro the problem of the crank sensor, there is a hole in the block where the sensor should be but its alot bigger that the sensor. is there some sort of bush or washer that you can buy to make the hole smaller if not can you by-pass the sensor
cheers
Old Apr 24, 2005 | 07:58 PM
JesseT's Avatar
JesseT
This is what you need.
http://www.kolumbus.fi/ulpu.tuominen/JT_kuvat/CPS.JPG
Old Apr 24, 2005 | 09:17 PM
monty's Avatar
monty
cheers mate
Old Apr 24, 2005 | 11:02 PM
richm's Avatar
richm
if it's relevant, bear in mind that the adaptor bolts onto the crankcase flange from the gearbox side, so you have to fit it while the engine is separated from the gearbox
Old Apr 24, 2005 | 11:48 PM
glenis's Avatar
glenis
what happens if you dont use a crank sensor on a efi CVH/ZVH ??
Old Apr 25, 2005 | 05:57 AM
JesseT's Avatar
JesseT
Nothing happens. And I mean nothing. It will never make a spark.
Old Apr 25, 2005 | 05:30 PM
monty's Avatar
monty
yeah know how it fits but dunno where to get one from cos ford has stoped selling them so any help would be good
cheers
Old Apr 27, 2005 | 12:04 PM
davidreader5's Avatar
davidreader5
HI,
ANY CVH EFI OR (CARB MODEL MK5 ) APPROX ON, FROM 1.4 TO 1.6. WILL HAVE THIS PART. CHECK OUT YOUR LOCAL CAR BRAKERS.
DAVE R.
Old Apr 27, 2005 | 05:18 PM
monty's Avatar
monty
yeah was gonna try the breakers at the weekend but its just the fact of having to take of the gearbox and fly wheel just to get a little washer but that looks like the only option
cheers
Old Apr 27, 2005 | 06:12 PM
richm's Avatar
richm
maybe Karl or someone may have one?
Old Apr 30, 2005 | 09:24 PM
monty's Avatar
monty
cheers for your help, got one today after 2 hours in the local scrapyard
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
fordrallycar
Sep 30, 2015 07:57 PM
A.t.p
Sep 29, 2015 05:04 PM
