2.8i water pump HELP
does anyone know where I might be able to find the outlet for the back of the water pump?
It sits on the right side as you face the motor and has 3 bolt holes (in a triangle but not evenly spaced). It seems that it has disapeered from the shop that I work at (open to public).
Should be number 5 on the engine blow up diagram.
I greatly need this to finish my project scorpio.
front inlet | water pump | timing cover plate | timing cover | REAR OUTLET
thanks,
TF
thanks,
TF
I found it, I got it from the states (of all places). The car runs great, just ticks a bit much for my taste. I believe the Rocker arms are worn. I am going to look into getting new arms and rods, and possibly hydralics.
are 2.8's normally this noisy?
would it be bad to snug the arms to just before they touch the rods?
Mark RS
Oct 12, 2015 06:01 AM
