2.8i water pump HELP
Old Apr 24, 2005 | 04:46 AM
TurboFlush's Avatar
TurboFlush
Default 2.8i water pump HELP
does anyone know where I might be able to find the outlet for the back of the water pump?
It sits on the right side as you face the motor and has 3 bolt holes (in a triangle but not evenly spaced). It seems that it has disapeered from the shop that I work at (open to public).
Should be number 5 on the engine blow up diagram.
I greatly need this to finish my project scorpio.
front inlet | water pump | timing cover plate | timing cover | REAR OUTLET
thanks,
TF
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
