help idle control valve can i...............?
Old Apr 23, 2005 | 05:00 PM
330bhpcoz's Avatar
330bhpcoz
Default help idle control valve can i...............?
i need 2 no if i can start and drive my car without the idle control valve pluged out reason being it idles up and down wen its on but wen i take it off it stops a little question is is it ok for now to drive until i get 1 etc cheers
Old Apr 23, 2005 | 07:10 PM
Dave McB's Avatar
Dave McB
yeah it can actually run fine without one.
All u need to do til u fix it or whatever is unplug it and adjust the idle screw (under the throttle body) to the right idle setting
Old Apr 23, 2005 | 07:17 PM
Lee @ Fusion's Avatar
Lee @ Fusion
as above , i dont run one at all ,
just set it manually with a manifold air restrictor
Old Apr 24, 2005 | 08:18 PM
richm's Avatar
richm
... and this is probably the problem, base idle adjustment not right, that is causing the fluctuations...
With the engine at normal operating temperature, unplug the idle valve and adjust the idle speed (screw in bottom of throttle body) to 850-900 rpm.
When you connect and disconnect the idle valve there should be no change in rpm, readjust if necessary.
If base idle is set below nominal idle speed of 850-900rpm, the idle speed valve will struggle to maintain smooth idle, and you will get fluctuation..
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
