all fwd wishone cars !!!!!!!!!!!!!!!!!!!!!
here are the new zoo wish bones to totally reove the old rubber bush stablitly problems and tyre wear sterring judder
there are to types road type ajustble and have a removable ball joint if worn
or track ones which have a rose joint that bolts to the hub instead of a ball joint
either can be used on the road
type one
very strong come from short oval racing design loads stronger than pressed steel design these are ajustable in camber in situ and also castor but not castor ajustable in situ
these are £320 deliverd
type 2
still very light and fully ajustable for camber and castor angles
these are not as strong as the oval ones but still far stronger than standard
£365 a pair
all kits come with 3/4 unf rose joints and are fully booted and all spacers are zinc coated so will not rust
comes with new bolts aswell
no doing above types of wishbones for all fwd fords
type one
type 2
£365 a pair
steerfromdarear
28
Jan 29, 2016 06:14 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
