Ariel amplifier........fitting help
Old Apr 22, 2005 | 07:20 PM
intruder's Avatar
intruder
Default Ariel amplifier........fitting help
I have been given an ariel amplifier from a sierra saph but need a little assistance fitting it.
I need to know which spade terminal is the remote switch from the stereo and which is the feed from the original heated rear screen feed? (There are 2spade ends. 1 normal, 1 little)
I also need to know the best way to extend the cables from the amplifier to the heated rear screen?
Cheers all
Old Apr 23, 2005 | 10:05 AM
Dave Henshall's Avatar
Dave Henshall
easiest way to fins out it get a test meter or a 12 v lamp with some wires attached, and connect it to each wire in turn and the other end to the shell, switch the heated rear window on and see which wire comes live, then just to prove it, connect the other wire to the lamp (with the other wire now disconnected!) and turn the radio onoff and check that it too lighs up when you expect it to.
hth.
Brian
13
Jun 30, 2010 07:06 AM
skypeller
Nov 23, 2009 11:18 AM
It's Czech Mate
12
Jun 13, 2009 09:31 PM
TIFF
Dec 22, 2005 02:08 PM
TILLIO
Oct 27, 2005 07:34 PM
