central locking& elec windows not working!!!!!!!!
Old Apr 21, 2005 | 06:59 PM
turbo.jon's Avatar
turbo.jon
Default central locking& elec windows not working!!!!!!!!
Right i had to change loom in car central locking worked fine same with windows but with last loom it was fine but now its not.ive checked all plugs in speaker wells they seem to be all conected to same colour plugs.checked fuse an thats ok any ideas what else i can look for???? as all other electrics work fine
cheers
jon
Old Apr 21, 2005 | 07:14 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
got the e/w workin then?
with the c/l does it work (motor sound even if its only the 1 ur turning with the key) on either side??
could just be a broken wire in 1 of the plugs or a pin pulled out if its only 1 side ignorin ya
i find the wire rots and leaves a dusty blue powder but the surround will look peachy and nice so u cant tell its broken
worth trying a light up leccy screw driver and a pos feed over the plugs to see if they are actually contactiin
same with mk3 fiestas but the surround (insulation) is less rubbery so they snap out and u can see em easier
i have a electric pack loom somwhere i could dig out at the weekend if u wanna try 1, the d plates c/l dint work so i would give u that mind u that was cos some pikey had crowbar'd the lock out of the skin
Old Apr 21, 2005 | 07:18 PM
turbo.jon's Avatar
turbo.jon
i new i forgot some thing no windows still dont work either must have wired some thing up wrong???
Old Apr 21, 2005 | 07:48 PM
DazC's Avatar
DazC
The wiring breaks usually in the door loops between the A pillar and the door itself where the wiring flexes...
Old Apr 21, 2005 | 09:57 PM
turbo.jon's Avatar
turbo.jon
will have a look in morn just seem weird how it used to work before
liam-rst
Aug 10, 2015 08:46 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
