Series One whining noise
Old Apr 21, 2005 | 07:52 AM
millsy's Avatar
millsy
Default Series One whining noise
Hi guys, hope you can help.
In the mornings I sit in my S1 warming her up and there's an electrical whining noise that's quite loud. It quietens down a bit by the time I get to work but it's still there. It sounds like it's coming from somewhere towards the back of the car and it was suggested it was something to do with a secondary fuel pump. Does anyone know for sure? Any help would be great.
Old Apr 21, 2005 | 08:27 AM
Blakeya's Avatar
Blakeya
Yep,
That will be the fuel pump making that noise. They do all do it but if it has got alot worse than it used to be then it's time to replace it before it packs up completely
Regards
Andy
Old Apr 21, 2005 | 08:59 AM
millsy's Avatar
millsy
Sweet. Thanks for the advice, I've only had the car a couple of weeks so don't know if it's got worse. Better replace it now to be on the safe side. Thanks again.
Old Apr 22, 2005 | 07:22 PM
matts1's Avatar
matts1
Yep feul pump, get some pics up in the gallery so we can see you motor, how are S1's
Old Apr 23, 2005 | 08:01 AM
S1MAN's Avatar
S1MAN
Had the same thing with mine a few years back. If you get under the car when it's running you can confirm that it's the pump, it's mounted just to the rear of the tank, can't miss it.
Colin.
Old Apr 23, 2005 | 12:33 PM
millsy's Avatar
millsy
Cheers guys. Had a look and it's definitely the fuel pump, as Colin said, I couldn't miss it. Seems quiet sometimes, noisey others, probably best replacing it.
And yep, S1s rule, especially on a sunny day, with the windows open and the turbo spinning up nicely. Puts you in a good mood for a day at work.
Old Apr 23, 2005 | 12:36 PM
millsy's Avatar
millsy
I think there are actually pics up on here somewhere already. It's D*** HKR and was in one of the discussions on how many d-plates were left. Swapped it for my Cossie, seems like it's in good nick, just need to find somewhere to take the arches, skirts etc off and refit them better as whoever restored it didn't do a perfect job.
AJC
Oct 8, 2015 11:09 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
gingeRS
17
Oct 2, 2015 09:42 AM
muz
Sep 30, 2015 08:29 AM
SMILER258
Sep 28, 2015 09:04 AM
