oil leak
if its the gearbox side, its not easy to fit,mine leaked and found it quicker to just disconnect everything from the engine wires/pipes and lift it out and do it, unless u have a ramp and take the gearbox out........
i would recommend buying the gasket carrier aswell as the gasket about 22 quid..
if its the oil pump side, oil pump could be leaking from the block, or the o-ring seal which sits in the oil pump, also the sump gasket around the oil pump area can fail.
hope this helps!
hope this helps!
deathrider666
Sep 28, 2015 06:12 PM
