Boost just drops right off
Old Oct 22, 2025 | 11:08 AM
Leloby's Avatar
Leloby
5 Year Member
Default Boost just drops right off
3dr. Stage 2. L6. Fresh rebuild. No leaks. Boost builds lovely, hits 12psi then drops to nout - revs rise, no power.
I can hold it at 10psi all day but push it further and turbo just kind of “cuts out”.
Any ideas folks?
cheers.
Old Oct 25, 2025 | 06:41 PM
cossie2's Avatar
cossie2
[QUOTE=Leloby;6840693]3dr. Stage 2. L6. Fresh rebuild. No leaks. Boost builds lovely, hits 12psi then drops to nout - revs rise, no power.
Any ideas folks?
cheers.[/QUOTE what map sensor you have right now
Old Oct 26, 2025 | 08:17 AM
Leloby's Avatar
Leloby
5 Year Member
what map sensor you have right now?
It’s a proper 3 bar MAP. I’ve tried others too.
Just found that the battery isn’t charging and the alternator is reading 16.5V.
Ill need to investigate the wiring as this is most likely the cause of the issue.
luxembourgrst
Oct 4, 2014 08:51 AM
Rogeyboy
Jan 27, 2011 04:01 PM
turblower
Mar 29, 2010 05:11 PM
CosRush
Nov 1, 2004 12:14 PM
Mar 14, 2004 05:37 PM
