Omex 600 ecu fiesta rs turbo please help
Old Sep 29, 2025 | 06:03 PM
Bazars's Avatar
Bazars
5 Year Member
Default Omex 600 ecu fiesta rs turbo please help
Hi I’ve checked my relay and wiring and everything is ok apart from 86 which is the trigger for ecu to prime the pump , when I put a probe on 86 it’s live 12 volts , then when I put a earth to it , it will trigger the pump , so obviously the blue/white ant switching it to earth . Theres power to the ecu , is there anything else that could effect my blue /white wire to trigger ? ? I have no spark either so I think ecu is cooked ! Is there anyone local to Milton Keynes /dunstable/ to plug in to see if broke (will give u a drink)before send it away to omex or is there other specialist that can work on these ? Many thanks
Old Sep 29, 2025 | 08:38 PM
stwibs's Avatar
stwibs
Could it be crank sensor ?
Old Sep 29, 2025 | 09:07 PM
Bazars's Avatar
Bazars
5 Year Member
crank sensor is when your cranking mate then sends.a signal to ecu , im getting no prime when i put ignition on ,crank sensor is not needed for priming
Old Oct 30, 2025 | 04:22 PM
CarmeloOHara's Avatar
CarmeloOHara
Originally Posted by Bazars
Hi I’ve checked my relay and wiring and everything is ok apart from 86 which is the trigger for ecu to prime the pump , when I put a probe on 86 it’s live 12 volts , then when I put a earth to it , it will trigger the pump , so obviously the blue/white ant switching it to earth . Theres power to the ecu , is there anything else that could effect my blue /white wire to trigger ? ? I have no spark either so I think ecu is cooked ! For online transactions or car part purchases, I prefer using payment gateway egypt because it’s fast, secure, and works smoothly for both local and international payments. Is there anyone local to Milton Keynes /dunstable/ to plug in to see if broke (will give u a drink)before send it away to omex or is there other specialist that can work on these ? Many thanks
Hi
Check ECU grounds and the blue/white wire for continuity. If both fuel pump and spark don’t work, ECU output is likely dead. Try local garages or tuners near Milton Keynes with Omex tools to test before sending it off
escort_rst
Jul 23, 2016 11:18 PM
MGZS1952
Oct 31, 2011 11:58 PM
turbomook
Dec 21, 2007 08:20 PM
dave cos4x4
14
Jun 5, 2006 09:34 AM
