Metering head rubber pipe
Old Aug 15, 2025 | 10:07 AM
Stephen RST's Avatar
Stephen RST
Default Metering head rubber pipe
Hi folks, could anyone tell me what the small rubber pipe coming out from my metering head is for? It's about 10mm dia and 6" long with several blue clips. It's located just under the air flap on the left hand side.
I removed my cylinder head for machining and can't remember if I touched it on reassembly. There's nothing obvious that it attaches to. I'm concerned I've missed something. I'm jot at the stage to start the car just yet.
Old Aug 15, 2025 | 07:28 PM
GVK.'s Avatar
GVK.
Put a pic up of it, might jog someones memory.
Old Sep 1, 2025 | 02:43 PM
nathansRS's Avatar
nathansRS
c++
That should be the return for the amal valve - https://www.burtonpower.com/amal-val...cvh-cv602.html
just block it off if you are not using one
Stephen RST
Aug 12, 2025 08:50 PM
rstg
Mar 5, 2014 04:37 PM
Oranoco
Dec 28, 2007 01:09 PM
Andy_RS
Jul 4, 2005 07:56 PM
MikeyXR2i
Dec 21, 2004 12:04 PM
