Sierra Sapphire MT75 gearbox issues
Old Apr 24, 2025 | 06:43 PM
kayhems's Avatar
kayhems
Default Sierra Sapphire MT75 gearbox issues
I have some problems regarding gearshifting on my 4x4 mt75 gearbox.
I just finished installing the gearbox after a replacement of a gearshaft, and now i have som issues with the first and second gear.
It turns out that the gear lever does not go stright up in first gear, or straight down in second.
They angle slightly inward, towards the middle to get into the final position.
The other gears goes straight into place.
Has anyone else here experienced a similar problem?
Best regards, Kay
File Type: mpeg
Old Apr 25, 2025 | 03:52 PM
Marc sierra's Avatar
Marc sierra
That looks awkward. I'm no expert on gearboxes, but I suppose it could have something to do with how the shift pin moves within the shift gate, as I believe that is what determines the H pattern of the gearbox. Maybe the shift gate is bent, although I wouldn't know how that would be possible.
Does everything work correctly apart from the lever not going straight? Does it still go in gear and does not jump out?
Chopshop85
Jun 14, 2016 07:59 AM
N.Saph
Aug 18, 2011 12:47 AM
boXXer
Jul 18, 2011 07:53 AM
jaiscossie
May 22, 2010 08:35 PM
JimRS
Apr 25, 2005 05:02 PM
