Saffy cosworth steering column bearing
Old Apr 6, 2025 | 07:19 AM
GaryNZ's Avatar
GaryNZ
Question Saffy cosworth steering column bearing
Hi Guys,
So ive found the loose steering wheel fix.
Whats the best method for fitting the cosworth steering column bearing?
Looks pretty tight from the pedal side. How do you drill from either side?
There must be a knack to this right..
Thanks.
Old Apr 7, 2025 | 11:41 AM
Marc sierra's Avatar
Marc sierra
I removed the brake and clutch pedal, the steering column and brake MC/ABS unit, and then drilled from the cabin side.
stuart1507
Ford KA
Apr 25, 2015 08:21 AM
marc_gti
Apr 27, 2013 07:56 AM
terranova
Ford Escort RS Cosworth
Aug 12, 2006 06:38 PM
