ecu temp sensor
Old Apr 17, 2005 | 12:16 PM
Jay,'s Avatar
Jay,
Sponsor
Default ecu temp sensor
hi igota bad fueling prob on my saff coz thet bad it nackers plugs on tick over and throws out so much smoke blue black grey it unreal guzzler has told me to check ecu and sensors so can anyone tell me in detail coz im thick how to test a coolant sensor with a multimeter i.e wat setting to use on the meter and is it easier to test the sensor off the car with hot water and wat should the reading be
cheers jay
Old Apr 17, 2005 | 01:48 PM
davidreader5's Avatar
davidreader5
HI,
Sent you a email with data sheet enclosed.
DAVE R
Old Apr 17, 2005 | 03:17 PM
Jay,'s Avatar
Jay,
Sponsor
david thanks for your info ill check this tomorrow cheers for your time
jay
Old Apr 17, 2005 | 11:14 PM
davidreader5
NO PROBLEM
DAVE R
Old Apr 19, 2005 | 06:39 AM
Jay,'s Avatar
Jay,
Sponsor
right thanks dave for all your help it wasnt the temp sender tho after all but i fitted a new on anyway ,but after a did all the checks i took it to my m8s workshop to check th c.o 9.32% after further looking around then tacking the ecu off we find the nice brass spring type bodge the webber call the c.o adjustment had cane off the variable can at the back of the screw so if this happens to u check this
thanks to
paul yorkshire spares and guzzler for all there help cheers lads
jay
Old Apr 19, 2005 | 07:39 PM
davidreader5
jay,
sounds daft now, but this would of been my first choice of checks, (CO%)but as you
asked just about temp sensor resistance, i assumed you would of been down this road first, still next time you will,
Regards Dave R.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
griffo69
Oct 4, 2015 11:58 AM
fordrallycar
Sep 30, 2015 07:57 PM
