Gear shift plastic bearing MT75
Old Mar 3, 2025 | 11:51 AM
Heitmann's Avatar
Heitmann
Default Gear shift plastic bearing MT75
looking for some advise
On my gear stick cradle the white plastic bearing is split. The one that fits around the gear linkage ball joint.
I fear it will cause play in the gear stick if I install it back on
I cant find any replacement - so is there anyone out there with experience or knowledge if a new replacement can be found?
thanks
Old Mar 3, 2025 | 01:16 PM
haz87's Avatar
haz87
Plastic weld it?
Or find someone with a 3d printer - doesn't look to difficult to replicate
Old Mar 3, 2025 | 03:07 PM
Zigu's Avatar
Zigu
10 Year Member
Vote also for 3D print or make one from nylon, which is way harder/durable material. For that you need lathe.
Old Mar 3, 2025 | 05:12 PM
Heitmann's Avatar
Heitmann
did consider the 3d print but wondering if it will be strong enough....
problem is it is quite hard to get on and over the "knuckle", so needs to be quite strong not sure a repair will hold
anyone know if this part is shared with other Ford transmissions?
Old Mar 3, 2025 | 05:14 PM
Heitmann's Avatar
Heitmann
that could work perhaps in nylon if someone with a lathe can copy it...
Old Mar 4, 2025 | 04:50 PM
dxcgnoc's Avatar
dxcgnoc
Would a very small jubilee clip or similar clamp round it , if so glue and clamp it
Old Mar 4, 2025 | 05:06 PM
dxcgnoc's Avatar
dxcgnoc
is it the same as this ?
https://shop.ford.co.uk/products/for...t-housing-bush
Old Mar 4, 2025 | 09:50 PM
Heitmann's Avatar
Heitmann
Originally Posted by dxcgnoc
nice find mate👍 - unfortunately not the correct one
thanks for the effort
Old Mar 18, 2025 | 08:06 PM
Glonio's Avatar
Glonio
thanks
If you can’t find the original part, maybe try looking for a universal bearing that fits. Sometimes people sell spare parts from scrap cars on forums too. You could also consider getting it 3D printed as a temporary fix.
Old Mar 25, 2025 | 03:52 PM
Heitmann's Avatar
Heitmann
so managed to get replacement from sierra'R'us - very helpfull they are 👍
Fernando_221
Jul 18, 2019 01:06 PM
gatekiller
May 21, 2010 03:51 PM
