Help, sierra v6 cranks good but will not start
Old Feb 26, 2025 | 08:47 PM
80s-new-man's Avatar
80s-new-man
Sierra Sapphire RS 4x4
Default Help, sierra v6 cranks good but will not start
Hi there,
I’ve had the engine on my 1992 XR4x4 2.9 rebuilt 7 months ago but has been running rich until I get the emerald ecu fitted. As I knew this I decided to clean plugs the other day. Today I took both lambdas out and cleaned them with carb cleaner.
All put back & didn’t touch anything else.
coming to start several times , I get crank and the occasional cough but no fire up.
i thought maybe the fuel pump had gone but I notice the no.6 cylinder exhaust outlet manifold is quite hot despite never firing up, whereas all others are stone cold. I guess that means fuel is getting there, but don’t get why the manifold is hot on only one branch.
i checked all fuses and ok.
all injectors were completely reconditioned.
im at a bit of a loss as she started first time and although ran a bit rich and lumpy because of the race cam, she never failed to start and run.
Grateful in advance for any ideas, cheers Stu
update:
Thanks for the advice! Yep checked those things - I didn’t check the plugs, as I’d only had em out a week ago & cleaned. However I take em out again and they were covered in fuel. My conclusion is, running rich for 7 months has mullered them, because as soon as I fitted some NOS motorcraft plugs she started and ran first time. Cheers have a good weekend!
daiwill93
Sep 2, 2022 04:36 AM
RSTurboSI
Oct 25, 2009 08:14 AM
The doomed
Jan 1, 2009 11:52 AM
