Replacing transmission fluid
Old Feb 5, 2025 | 03:07 PM
Dale. H's Avatar
Dale. H
Default Replacing transmission fluid
My reverse light switch has been leaking transmission fluid on my 01 fiesta Zetec-s mk4. I'm replacing it and figured I'd replace the fluid while I'm down there but I can't find the drain plug. Any tips?
Old Feb 5, 2025 | 07:27 PM
GVK.'s Avatar
GVK.
There isn't a drain , you have to remove a drive shaft to drain it, TBH if you're quick the fluid should gush out when replacing the switch... depends how mush has leaked out!
a1i.c
Jan 18, 2011 07:20 PM
Punkie
Jan 29, 2009 03:43 PM
OwenGsi
Nov 9, 2005 07:55 PM
Drewman
Jul 29, 2005 07:51 AM
