Rs turbo steering wheel nut
Hi everyone,
as the title reads, does anyone know what nut I need as I have misplaced the one I took off and I am not sure what size or thread pattern I’ll need to try and find to put the steering wheel back on!
thanks in advance
Blake
thanks in advance
Blake
Hope you dont mind me hijacking this.... I swapped my steering wheel last week and was expecting a self cancel for the indicators, mine is a 1990 and the plastic washer was smooth no clips on the side so i wanted to ask is yours the same and could the self cancel plastic bit be added to switch off the indicators?
When you go from a Tesla to an RST you need a few modern touches....
Thank you, I have put a cosworth steering wheel on but didn’t really test the self cancel as it went straight in for it’s MOT so I will have a look when it comes back, hopefully swapping from the MOMO to a ford wheel has done the trick
it’s a 1990 RST mk 4, thank you for your reply also 😛😀
HI Blake, i have got the car back, steering wheel fitted but it doesnt self cancel, i will take it off when i can and post some photos maybe something is broke inside, wouldnt put it past this car to have broken parts ha ha
hi mate, that’s really annoying isn’t it, I hate it when things don’t work! Definitely put some pictures on and hopefully we can help you out abit more
