Escort RS Turbo bits
Old Nov 5, 2024 | 04:26 PM
P-ssedrightoff's Avatar
P-ssedrightoff
Default Escort RS Turbo bits
Escort RS Turbo Mk 2 par
Standard front calipers (will need refurb)
Auxiliary Air Valves x2 (tested good) £50 each
Original starter, scruffy but functional £30
Bonnet catch, battery clamps, servo to wing bracket £40
Ignition Coil and Chromed mounting bracket (as new) £50
Fuel sender and loom (88> £40
Burton Stage 3 big valve head, no cam but double valve springs
and rocker arms included £600
Distributor vgc £60
Hub carriers (pair) o
LSD Gear box, slight whine in 2nd, LSD good £400
Inlet manifold & throttle body £100
Minted set of Team Dynamics Gold alloys 16" Toyo tires
look almost new but out of date. £300
Original steering wheel. offer
Battery to starter loom £30
Full set of engine/gearbox mounts and crossmember
all powder coated red
New Piper valve springs and retainers £60
Way too much other stuff to list, try me.
Can post smaller stuff at cost.
Last edited by P-ssedrightoff; Nov 16, 2024 at 01:47 PM. Reason: removed sold parts
zippyobrien
Feb 17, 2013 08:22 PM
robrs666
Aug 7, 2011 05:01 PM
3dr cossie
Mar 22, 2011 01:01 PM
NEEDFORSPEED
93
Mar 11, 2009 10:28 PM
BillyCabrio
Sep 10, 2006 09:39 PM
