No boost?
Old Oct 21, 2024 | 04:39 PM
RSBryden's Avatar
RSBryden
10 Year Member
Default No boost?
fiesta mk7 st
Currently scratching my head with this issue…
Bought the car as a non runner. Had a new modified bottom end fully assembled and supplied by pumas speed. The original
Head I had sent off to be compression checked and skimmed. New pcv Valve alternator water pump etc , original turbo 106k on the clock.
During running the engine in it was coming up a fault and going into limp mode. ( over boosting) this was jist reving up to 3.5k .. car had an air leak so we replaced the pcv valve. Still was over boosting. So we dl the data from the ecu sent it off and had it set to standard tune. Now the car doesn’t over boost and no lights appear on dash. The dump valve makes all sorts of different noises , obviously the wsshhh and sometimes a screech. Gently building boost the car will hesitate after 3.5k and feels like no boost at all, if I drive the car and change at 3k I get the wsssh sound and sounds great, the more boost that builds the car then feels like it’s looosing boost then no boost or something .boost Pics up hard to 3.5k then looses boost….havent taken the car over 4K revs yet as im only 270 miles into the running in phase….
Any ideas would be appreciated.
Car is definitely building boost up too 3.5k
Old Oct 24, 2024 | 09:25 AM
vlaestor71's Avatar
vlaestor71
услуги юриста по банкротству физических лиц: важный шаг к финансовому освобождению
Если вы оказались в ситуации, когда долговая нагрузка стала непосильной, а погашение кредитов и займов вызывает постоянный стресс, важно не оставаться наедине с проблемой. Одним из эффективных решений может стать банкротство физического лица. Бесплатная консультация юриста – это первый и необходимый шаг на пути к грамотному и законному выходу из долговой ситуации.
Old Oct 24, 2024 | 07:14 PM
GVK.'s Avatar
GVK.
^^^^ handy
Birdsfocusst225
Dec 11, 2021 07:39 PM
seanex
Dec 9, 2007 05:41 PM
chRiS & dawn
Nov 30, 2003 08:33 PM
Oct 29, 2003 06:48 AM
