Engine timing
Old Aug 27, 2024 | 01:35 PM
2much's Avatar
2much
Rs turbo owner
Default Engine timing
Seems unknown to me that timing is the cause of the head gasket trouble I've been having also after speaking to a reputable tuner he believes a comertic gasket is the way to go and retard the timing, so guys where should I aim the timing for, running 10 psi it has a scorpion exhaust, k and n air filter and a larger front mounted intercooler
Old Aug 27, 2024 | 01:36 PM
2much's Avatar
2much
Rs turbo owner
Not looking for massive power just to make it safe and useable till I can get it onto the rolling road for a tune
Old Aug 27, 2024 | 07:39 PM
GVK.'s Avatar
GVK.
Didn't the reputable tuner tell you what to set the timing to?
Old Aug 27, 2024 | 08:51 PM
2much's Avatar
2much
Rs turbo owner
No just said to retard the timing and use a cometic gasket, keeps going due to detination
Old Aug 27, 2024 | 10:20 PM
GVK.'s Avatar
GVK.
I havent had a rs turbo since the 90s but i do remember that if its not set right the timing makes so much difference to how it runs and retarding it may make it run hotter and feel flat as a fart,
Gazz_
Jun 7, 2013 01:00 PM
arron matthews
Jul 18, 2011 07:51 PM
Benxrrst
Dec 20, 2007 10:41 AM
steventoon
Jan 13, 2006 09:26 PM
AlexF
15
Mar 25, 2005 08:56 AM
