Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Fiesta ST150 MTX75 conversion
Old Aug 23, 2024 | 09:46 PM
SamB7's Avatar
SamB7
Default Fiesta ST150 MTX75 conversion
I'm looking for some information around swapping an IB5+ for a MTX75. In particular:
Drive shafts, what model they were from and were they customised.
Shifter, which one to use and what needs to be modified.
Mounts, I assume they need to be custom built or can an existing mount be modified?
Clutch, can I use the ST150 cover with 23t plate? If so what is the clutch plate from.
Old Aug 24, 2024 | 07:51 PM
GVK.'s Avatar
GVK.
Before you worry about that lot.
ST150 have a Mazda devired bell housing pattern so not applicable to the Ford type.
Old Aug 24, 2024 | 08:09 PM
SamB7's Avatar
SamB7
Correct, as does the MTX75. That's really my problem as only the ST150 has the bellhousing for the Mazda pattern so finding a replacement IB5+ is like looking for a needle in a haystack ( as least in NZ ). Hence looking at converting to MTX75 which are easily obtained and will bolt up to the engine.
Old Aug 25, 2024 | 08:45 PM
XR2's Avatar
XR2
Why would you want to replace your gearbox?
Old Aug 25, 2024 | 09:02 PM
SamB7's Avatar
SamB7
It's done what I'm told is a pretty common problem with the IB5+ and broken the pin that locates the spider gears. This resulted in the spider gears exiting the casing. Finding a used casing in NZ is proving very difficult so I'm looking at other options.
Marc D
Nov 17, 2012 09:29 AM
evan2401
Fiesta's Other !
Aug 11, 2012 11:17 AM
cozi500
Jan 20, 2010 11:50 PM
cos47
16
Nov 26, 2008 10:56 PM
DENNIS
Feb 27, 2007 10:02 PM
