Converting 2006 ST TDCI to ST220 -
Old Aug 18, 2024 | 04:13 PM
Bren1977's Avatar
Bren1977
Default Converting 2006 ST TDCI to ST220 -
HI all
Would an ST TDCI that is same spec as a 3.0l ST220,with Hatchback, sunroof, climate control etc. be an easy enough task (have the tools and equipment but not so much the time) to swap over to the ST220 variant?
Before I consider such a project of striping down both cars to do the swap is there any quicker way regarding loom swapping (so I don't have to take stuff out needlessly)?
i know ecu, clocks, key barrels, engine, fuel tank, fuel lines, fuel filler cap etc need to be swapped, but can I get away with just removing the engine loom for running the diesel lump and swap across the 3.0L electrics? brake servo etc have same part numbers as that of the ST220.
Or, as I think is the case, both cars need to be stripped down and all wiring etc swapped over?
Brasso
Jan 16, 2010 10:31 AM
4x4
16
Mar 28, 2008 08:41 AM
robrs
Ford Mondeo Including ST
12
Mar 21, 2008 01:32 AM
drperry
Jan 22, 2008 08:44 PM
