Escort RST s2 Turbo options
Old Jul 27, 2024 | 03:36 AM
Wally86's Avatar
Wally86
Default Escort RST s2 Turbo options
Hi.
I'm wondering what options there are for replacing the standard Garret T03 Turbo with some other instead of upgrading the original to a 2/3 hybrid, no one seems to have the turbo in stock, so they need you to ship it to them and due to where i live, the turbo has to be shipped out of the country and the shipping alone is insanely expensive.
The goal is around 220-230 bhp (with all the typical upgrades)
Cheers.
Old Jul 28, 2024 | 07:48 PM
stevieturbo's Avatar
stevieturbo
C**t
Any turbo change will also require spark/fuel tuning etc to suit.
If you are prepared to adapt some parts to make a different turbo fit, then there are thousands of options
Something like a GT2860 would probably work well.
This would normally be a T25 flange, but your manifold could likely be drilled/tapped to suit and you'd need to remake some pipes.
Or even a small Hoslet is pretty cheap https://www.stavtech.co.uk/home/stav...-and-downpipes
https://www.speedingparts.co.uk/p/tu...BoCpWEQAvD_BwE
There will literally be hundreds of similar options
Old Aug 15, 2024 | 09:07 PM
Wally86's Avatar
Wally86
Yeah, i've been thinking of the TD04 for Saab 9000 Aero or maybe a T3 from a Sierra Cosworth. Seems that the Saab one is the easiest to mount? I'm not going for mad power around 220bhp with good spool.
Old Aug 15, 2024 | 09:12 PM
stevieturbo
C**t
An ancient T3 from a Cosworth would be a laggy piece of shit.
Old Aug 16, 2024 | 07:09 PM
GVK.'s Avatar
GVK.
LOL stevie tells the truth.
simontrayler
May 12, 2014 08:59 PM
adam.d
Jan 22, 2009 02:26 PM
