Rear Brake valve help
Old Jun 15, 2024 | 06:44 PM
rick o'shea's Avatar
rick o'shea
Default Rear Brake valve help
Does anyone know the part number for the 3 Door Cossie Brake Pressure reducing valve ? Or where to source one in 2024 ?! Mine has just started leaking - bearing in mind it's lasted 38 years that's probably not bad going !
I assume it's the same item as used in the XR4x4 and Granada / Scorpio models of the era but without the Ford part number it's difficult to confirm...might even be the same item as used in the 2wd Saph ?
Many thanks !
Mr_Simpson
Jul 15, 2022 01:01 PM
cosysop
Feb 6, 2012 08:52 PM
105epwr
Apr 26, 2009 09:10 PM
182sam
13
May 24, 2006 07:00 AM
182sam
May 19, 2006 07:42 AM
