Suspension
Old May 31, 2024 | 05:56 PM
DoorsyRS's Avatar
DoorsyRS
Post Suspension
What are you guys running on S2 RST's and what would you recommend i seem to be slanting towards Koni's at the moment whats your experience with them?
Thanks.
Old Jun 1, 2024 | 09:08 PM
Ridgey's Avatar
Ridgey
See what you can get.
i asked around and suspension kits weren’t available, other than coilovers.
so I just bought a spring kit in the end from SPAX
Old Jun 6, 2024 | 02:22 PM
RST4ever's Avatar
RST4ever
Asuming you want normal suspension and not coil overs, if you can get adjustable Konis or Bilstein that is the best bet. But they are impossible to find nowadays. I found though a company here in Spain that will rebuild any shock absorber,so if your car happens to have good quality ones that could use a rebuild I can link you to them. Springs, unless you want to lower the car and go much stiffer, or unless the original ones are really destroyed, I would keep them. New, proper quality shocks will make everything much stiffer in the correct way, don't save money on dampers thinking spring will solve the handling as it is quite the opposite - if you only change one component, it should be shocks!!
Old Jun 17, 2024 | 11:53 AM
DoorsyRS's Avatar
DoorsyRS
Thank you buddy
kyam786
Mar 2, 2016 11:00 PM
Mancunian Lee
Feb 12, 2007 09:42 PM
cossiemanden
Nov 10, 2006 08:56 PM
