MFI HP fuel pipe - pump (banjo) to metal fuel line (push fit)
Old May 13, 2024 | 08:00 PM
Cawood's Avatar
Cawood
Default MFI HP fuel pipe - pump (banjo) to metal fuel line (push fit)
Hi guys
In the process of recommissioning the RST and need to replace the HP fuel pipe that goes from pump to metal fixed fuel line. On the side of metal fuel line it's push fit connector (which has failed)
Any ideas where I can source another from? Struggling to find one.
Is the same part used on any other models?
Old May 14, 2024 | 05:50 AM
XR2's Avatar
XR2
Use a cutting ring fitting on the metal fuel line.
Old May 20, 2024 | 01:20 PM
Cawood's Avatar
Cawood
Thanks, but how does that work exactly. As it's the plastic push fit connector on the hose/pipe that's failed
Old May 20, 2024 | 10:00 PM
boost monster's Avatar
boost monster
I got my replacement from eBay, it was a while ago and I’ve not looked for one since. It done away with the plastic fitting to the hardline and had an olive type compression fitting.
Old May 21, 2024 | 07:43 AM
XR2's Avatar
XR2
https://www.autoteile-plauen.de/artikel-2436.htm
Old Jun 5, 2024 | 08:46 PM
Cawood's Avatar
Cawood
Cheers, been searching eBay for a while for full hose. No joy
Did you use the same type of compression fitting that XR2 recommends. Did you source parts from UK?
Old Jun 5, 2024 | 08:48 PM
Cawood's Avatar
Cawood
Great thanks mate for link, understood.
Is that part the correct size for this application then?
Shame that's In Germany, think I'll be able to source from a UK supplier? Maybe hydraulics parts companies?
Old Jun 14, 2024 | 08:39 AM
P-ssedrightoff's Avatar
P-ssedrightoff
Think I have the part your looking for in the garage somewhere. Will have a look.
Old Jun 14, 2024 | 09:01 AM
XR2's Avatar
XR2
Yes, that's for the 8 mm metal fuel line and the bigger (8 mm outside, 6 mm inside) red polyamide fuel line. This is a perfect fit as you won't need any adaptors then. Just push the connector into the polyamide fuel line and screw it onto the metal line.
These parts are used for hydraulics, too. Still it's not easy to get all the parts for such a neat fit, you might have to buy the connector for the polyamide fuel line, the one for the metal line and one or two adaptors between. Just be careful to buy a connector for a polyamide/plastic fuel line, the ones for rubber hoses look similar, but are different!
Old Jun 19, 2024 | 01:58 PM
Cawood's Avatar
Cawood
Thanks mate! let us know if you have a spare your willing to part with
Old Jun 19, 2024 | 02:13 PM
Cawood's Avatar
Cawood
thanks mate, appreciate the info
proving difficult to get any of these hydraulic parts suppliers to give me a clear answer, just keep asking more and more questions, so still on the hunt
Old Jun 19, 2024 | 07:06 PM
boost monster
Just searched my eBay history and this is where I got mine. But if not available just get some an6 to 8mm hardline fittings from Torques
marky_g
17
May 8, 2022 05:26 PM
Bransby
Feb 28, 2020 11:56 AM
mentalasanything
Mar 5, 2017 09:00 AM
hughy
Sep 19, 2009 09:05 PM
MATCOS
Ford Escort RS Cosworth
Jan 22, 2007 06:23 AM
