Ford fiesta st150 mk6 starting problem after battery change
Old Apr 27, 2024 | 07:13 AM
cossie2's Avatar
cossie2
Default Ford fiesta st150 mk6 starting problem after battery change
Hello,
Maybe someone had same issue with Ford fiesta st150 mk6..After dead battery on display there is a engine fault message engine temperature high and the car can not start not even crank over..Checked all relays,fuses,connected new ect sensor but it can not crank,also obd can not connect at all with diagnostic..Is the ecu burned?
Any info would be great
Thanks
FORD RS MAD
Dec 1, 2014 05:19 PM
ADT168
Jun 10, 2012 10:53 AM
craigybaby
Apr 29, 2012 10:29 AM
Swaidey
Fiesta's Other !
Feb 10, 2011 07:40 PM
Andyz
Jul 12, 2007 07:29 PM
