Fuel Pump Relay
Planning to test injectors Purple pump relay showed no signs of 87 30.
Looked on Ebay and sussed it. Forgetting I was looking at the relay
went down forgot to reverse the diagram.
Bridged 31 and 87 before I twigged what I'd done wrong.
Is this likely to have damaged anything?
Looking at the wiring diagrams 31 seems to go to voltage protection
which means absolutely nothing to me.
Thanks in Advance.
Thanks in Advance.
Sussed it working, just worried doing it the wrong way broke something but cheers for taking the trouble to reply. Sure O.A.P. Pete
will come to my Rescue, as usual
Thanks again Pete, you've steered me in the right Direction so many times (as Si74 before I had to Re Register), you should have your own advice page on here!
Have a nice weekend and thanks again.
choppy1979
Oct 18, 2022 07:10 AM
Lee Reynolds
Jan 28, 2009 10:58 PM
