Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Flo-Flex bushes Issues
Old Jan 12, 2024 | 07:56 AM
westie8237's Avatar
westie8237
Default Flo-Flex bushes Issues
Flo-Flex bushes
Hi has anyone fitted these to the rear beam of a fiesta mk7
I bought a set, they come with the plastic bush, a replacement nut bolt + washers and a metal tube that fits inside the plastic bush
Issue with the set that I have bought is that the bolt is a very loose fit inside the tube, I would say the internal width of tube is about 1-1.5mm too big for the bolt
Anyone else had a experience of these bushes for the fiesta rear beam
Old Jan 12, 2024 | 09:55 AM
haz87's Avatar
haz87
Flo-Flex (was Deflex a very long time) have always had hit and miss quality. I've had bushes that have lasted years, I've had bushes like yours that weren't even fit for purpose.
If there is slop between the bolt/tube interface, there is little you can do to take up the gap beyond machining a new tube. You could try speaking to Flo-Flex and see if they'll send out a new tube in case its just a badly machined one, but equally it might be worth just returning the lot and getting Powerflex or a brand like that. Cost a bit more but you don't get this hassle
Old Jan 12, 2024 | 11:09 AM
westie8237's Avatar
westie8237
hi, going to send them back, i spotted the issue as soon as they arrived so havent fitted them, not sure which brand to go for, euro car parts do the powerflex kit
2Litre
25
Oct 8, 2014 05:32 PM
rich123
Feb 18, 2011 09:33 AM
Sp3no
Sep 11, 2010 09:54 PM
155lee
May 26, 2009 09:17 PM
garyrs
Jan 14, 2008 12:30 PM
