V6 cologne distributer basic set up
Old Dec 6, 2023 | 08:08 PM
Robzilla's Avatar
Robzilla
Default V6 cologne distributer basic set up
I need a bit of help setting up distributer, I have number 1 set to tdc on compression, is it correct that I need rotor arm pointing to number 1
Old Dec 6, 2023 | 08:45 PM
GVK.'s Avatar
GVK.
Yep. then you need the firing order 1-4-2-5-3-6 in the direction of rotation of the dizzy.
Old Dec 27, 2023 | 08:35 AM
ray barker's Avatar
ray barker
there may even be a scribed mark on the side of the dizi that you point the middle of the rotor arm at for no1
Old Dec 27, 2023 | 08:58 AM
Robzilla's Avatar
Robzilla
So with all that lined up, when dizzy is in does number 1 point to the bulkhead
Old Dec 27, 2023 | 11:17 AM
ray barker's Avatar
ray barker
ive not seen one for 35 yrs is there a scribed line on top of the dizi body where the cap sits if so thats no1. i just had a quick look online there saying no1 is the first cylinder looking into the engine bay on the right bank nearest the rad stood in front looking at the windscreen. this does ring a bell. your better of looking up a workshop manual.
Old Dec 27, 2023 | 11:37 AM
Robzilla's Avatar
Robzilla
Yeah I’ve got number one on the block and it rocking on compression, just wanted the rough position of distributer as it can be put in in different positions, I have googled some pics I think it’s all ok
Mark 3D
Mar 7, 2011 01:51 AM
The Sludge
Jun 3, 2010 09:00 PM
Taz
Sep 13, 2006 09:26 PM
Beach
Jun 8, 2005 04:09 PM
OldSkoolRS
Jan 30, 2005 12:56 PM
