Help!
Old Oct 10, 2023 | 11:30 AM
ESTsierra's Avatar
ESTsierra
Default Help!
1993 2.0 doch sierra running rough, wont start unless pushing accelerator pedal all the way to the floor, runs rough, when giving gas it revs for a bit and then lets out loud bang, ive changed fuel filter, spark plugs, oil, oil filter, cleaned distributor. What could be the issue, took throttle off and measured tps it seemed to be in order. I have no idea what to do, tried checking for air leaks with brake cleaner but didnt find anything. The car was sitting for 2-3 years outside before i bought it. Any ideas, suggestions what i should check/replace?
Old Oct 11, 2023 | 08:46 AM
focusv8's Avatar
focusv8
Try draining or just adding some new fuel.
Old Oct 11, 2023 | 08:48 AM
ESTsierra's Avatar
ESTsierra
ive added new fuel and put injector cleaner also
Old Oct 11, 2023 | 09:09 AM
haz87's Avatar
haz87
What do you mean by "cleaned" the distributor?
At a minimum I'd be changing the rotor and cap - they easily fluff up over time/through lack of use. HT leads are worth considering too.
Once changed I'd also be verifying ignition timing.
Old Oct 11, 2023 | 09:11 AM
ESTsierra's Avatar
ESTsierra
HT leads? I used sandpaper to clean contacts
Old Oct 11, 2023 | 10:59 AM
haz87's Avatar
haz87
HT leads = Ignition leads
Shredtheibanez
Apr 16, 2010 02:50 PM
griffo69
Sep 20, 2009 10:44 AM
Sp3no
Mar 17, 2008 07:24 PM
purple_fiesta
Apr 6, 2007 01:31 AM
Mark 3D
29
Mar 18, 2006 09:38 AM
