We did a head gasket on my car and ever since it's not idled properly. It's also over fuelling badly at idle. I changed the coolant temp sensor but it's made no difference. The car does seem to drive ok, it just won't idle? Any ideas?
It's been off the road since 2018 with this problem, but I think it's about time I try and sort it lol
I second the above. The fuel pressure regulators go bad on these cars. Mine was over fuelling and wouldnt idle and it turned out the regulator was leaking a small amount of fuel into the air line to the intake manifold and unmetered fuel was causing it to run too rich. If you take the air line off the regulator and fuel comes out thats your culprit.
Even if its not your problem change the regulator anyway if its never been changed as when they leak they drop petrol onto the dizzy below and Im sure you can imagine the result!
Have you got the fault code reader? It should tell you if there is an issue on any of the sensors. Alternatively check the voltage and resistance via the ecu connector. Ill post what you need below and are my go to guides for any fault finding.
Alternatively if youre Kent way Im happy to help you if youre local.
I have also issues with my. Idle is bad, when engine is cold. Idle goes down, up down up from 950-600-950-600....
Car has MSD 330 chip, with closed loop.
Car is starting also badly, when it´s cold. When engine is warm idle is ok and also car starts fine.
Changed parts:
-MAP
-Fuel pressure regulator
-Air temp sensor
-Coolant temp sensor
-Inlet gasket (was leaking from middle part of inlet manifold)
-Fuel pump loom
-Spark plugs
Done so far:
-Checked fuel pressure
-Cleaned ICV
-Adjusted idle (plug OFF ICV socket, turned electric devices off and adjusted idle speed to 500-600RPM and then plugged ICV socket back)
Next ideas:
-Lambda?
-Clean injectors?
-Faulty injector?
Changed parts:
-MAP
-Air temp sensor
-Fuel pump loom
-Spark plugs
Done so far:
-Cleaned ICV
Next ideas:
-Lambda?
-Clean injectors?
-Faulty injector?
Ideas welcome....
check the plug on your distributor and make sure your phase sensor in the distributor is in good condition
