Clutch pedal position
Old Aug 4, 2023 | 08:23 PM
BlakeMoyle's Avatar
BlakeMoyle
Wish I had more time!
10 Year Member
Default Clutch pedal position
Hi all,
I have a problem I’ve just fitted a ib5 box and fitted the clutch cable back up and the pedal is sitting really high it’s actually touching the column 🤦🏼 have I done something terribly wrong or is do I need to use a different cable or something I’ve literally just had about enough with the car it’s just problem after problem 🤬 should I have the little black arm on top of the quadrant as I can’t see it in position or a spring or anything but the clutch pedal sat fine before when I took it out a year or so ago. Any help will be appreciated thanks in advance some pics of my progress so far
Old Aug 5, 2023 | 07:44 PM
boost monster's Avatar
boost monster
I don’t think the gearbox swap has anything to do with your problem as the clutch actuation is the same as a B5. Clutch or cable would be my thoughts.
You need to be resilient to problems with modifying car as they rarely end.
Old Aug 5, 2023 | 09:40 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
hi mate,
thanks for the reply, I have been doing some research and think I’m just going to chuck a hydraulic clutch kit in it from eBay, hoping that will solve my issues, I know my mate keeps saying the same thing I just lose my patience too quickly with it.
saph in dorset
Jul 9, 2015 08:15 PM
Weeksy
11
Aug 9, 2011 01:58 PM
B13 JUS
Feb 9, 2009 07:46 AM
fordrallycar
Jan 7, 2008 08:15 PM
