Fuel tanks
Old May 19, 2023 | 08:41 PM
2wd's Avatar
2wd
Default Fuel tanks
Hi .. does anyone know if a Mk1 Sierra XR4i fuel tank is the same as a Mk2 Sierra Cosworth fuel tank ... ? They look the same with internal swirlpot, all the stud and holes ..
Old May 19, 2023 | 10:51 PM
BIG LEE's Avatar
BIG LEE
im sure sender units are differnt sizes
Old May 20, 2023 | 08:39 AM
2wd's Avatar
2wd
Hi ... well that also my concern ...
My hope was that somone here knew if there is a difference ...?
Old May 20, 2023 | 12:12 PM
BIG LEE's Avatar
BIG LEE
i could get a new petrol tank i think like out price has gone up now im sure there about Ł175.00 inc postage
Old May 20, 2023 | 12:36 PM
2wd's Avatar
2wd
I take that its a reproduktion tank and not an OE tank ...?
The thing is that Ive been offered brand new XR4i tank for a very good price, but I need to have it send .. so I need to find out if the level sender form my old tank will fit ...
Old May 20, 2023 | 02:05 PM
BIG LEE's Avatar
BIG LEE
hi yeah aftermarket tank here in uk a genuine tank if you find one will cost Ł500 area... im guessn you dont have a xr4i you have cosworth ?
Old May 20, 2023 | 04:45 PM
2wd's Avatar
2wd
Yes I have a 88/89' 2wd Cosworth .. and Ive just done a 3 year "refurb" and all was ready to go ...but I found that the stud where the return fuel come did a hair fine spray .. direct over at the FP cradle ... so at the moment its ok as Ive "sealed it with som chemical stuff for that kind of leaks" but a new tank is needed ASAP ..
As it is Ive been offered a new tank .. but its as I wrote for Mk 1 XR4i to a good price .. and looks similar ...only the level sender hole makes me hesitate to buy it ... so if anyone knows if its the same size hole for the sender ....
Old May 21, 2023 | 10:45 AM
stevieturbo's Avatar
stevieturbo
C**t
That's a totally different scenario.
Now you're asking is a 3 door the same as a 4 door Sapphire ?
I really doubt they will be the same ?
Have you got good photos of both ?
Is your existing tank completely rotten, or can it not be repaired ?
Old May 21, 2023 | 12:38 PM
2wd's Avatar
2wd
Well my start quetion is the same .. would I be able to use a Mk1 XR4i fuel tank on my 88/89 Cosworth... ,..,only thing Im in doubt about is the hole for the level sensor ... all other looks the sam.
No my old tank is ok ,,except for the return hose stud and the vent hose stud who both have some small holes...
Old May 21, 2023 | 01:09 PM
stevieturbo
C**t
If you think it is the same shape, but different hole....get the level sensor to suit it too ?
That way you're covered. It probably uses the same resistance range anyway, and even if it is different, it there are adapters to make it work
Old Aug 6, 2023 | 07:18 AM
ray barker's Avatar
ray barker
if you really needed to use to use a different tank cut out the top of the saff tank around where the sender goes in. do the same on the different tank but slightly smaller then brase or silver solder it together with lthe over lap joint. thats if you can clean the saff tank as they get very rusty in that erea
j@mie
Mar 19, 2016 07:08 PM
Toe Knee
Nov 5, 2011 08:32 PM
YBT200
Ford Escort RS Cosworth
Jun 16, 2008 09:13 PM
cossiematt
31
Dec 13, 2007 07:38 PM
CossieRich
Jun 17, 2004 01:44 PM
