Wheeler Dealers ST225 Episode May 8th
I'm permitted to let you all know the **Focus ST225 ** episode of Wheeler Dealers is due to be screened on
Mon 8th May on Discovery Channel at usual 9pm
Season 18 - Episode 8
Can’t believe they re bored the cylinders lol. I was under the impression the hole reason they can crack is because they are thin at the top because Ford over sized them from Volvo spec. Brave going further. Surly you would fit new liners or a used engine
I guess as it was standard it was ok ish but if wanting to upgrade power wont be long before it craps itself, I did speak to Mike and asked prior to show being aired but was pretty tight lipped as you can imagine, as I knew one of the chaps at the meet he took the car too, so I have been on his case for months
phil_rs
Dec 19, 2009 04:05 PM
