Sunroof frame?
Old Apr 5, 2023 | 04:42 PM
K464TGV's Avatar
K464TGV
10 Year Member
Default Sunroof frame?
Hi all, does anybody know what size the screws/bolts are that fix the sliding gear to the sunroof metal frame on the underside through the 6 holes (3 each side). I’ve got a replacement glass/frame in great condition as my original has rusted in the front corners. I can’t remove the rear screws/bolts to get the dimensions and would rather wait for the auto glass chap to remove/refit (front screws/bolts look like blobs of rust!). Will be buying stainless versions but just need to know what size??? Any help would be appreciated! Thanks very much in advance
Old Apr 5, 2023 | 07:51 PM
Mark V8's Avatar
Mark V8
From memory (which isn't as good as it used to be) they were M6
It's been a while since I did my sunroof but did take some pictures.
Old Apr 5, 2023 | 07:55 PM
Mark V8's Avatar
Mark V8
There are brass inserts moulded into the plastic frame you need to be careful with if the bolts are rusted, the plastic frame is brittle with age and won't stand up to much abuse getting the bolts out.
Old Apr 6, 2023 | 07:09 AM
K464TGV's Avatar
K464TGV
10 Year Member
Cheers Mark, much appreciated! Yeah, they all seem seized/stiff so have coated them in WD40 ready for sunroof repair chap to tackle the job next week. All the best
Old May 10, 2023 | 09:25 PM
K464TGV's Avatar
K464TGV
10 Year Member
Sadly plastic slider on one side was badly cracked around forward mounted bolts (which couldn’t be removed), however I managed to source replacement sliders with another sunroof panel in great condition (so a replacement for the future, should I need it) In the end I needed M5 bolts which were 10mm long, but super happy with finished article 👍
saph in dorset
Feb 10, 2015 09:26 PM
onionlover
Aug 10, 2014 09:59 PM
killa_paul
Jun 27, 2012 02:10 AM
killa_paul
Nov 1, 2010 07:35 PM
woodz77
Nov 8, 2006 04:00 PM
