Header tank capacity
Old Apr 1, 2023 | 10:53 AM
scoooby slayer's Avatar
scoooby slayer
Default Header tank capacity
Does anyone know capacity of the standard 2wd or 4x4 sierra cosworth header tank ?
Old Apr 1, 2023 | 08:46 PM
Mark V8's Avatar
Mark V8
Can't help with an answer to your question but if you need extra capacity Pro Alloy can make a taller version.
I had to go taller to make sure it would have enough height to bleed the air out with the V8 fitted.
Old Apr 1, 2023 | 08:55 PM
scoooby slayer
​​​​​How much coolant does that hold mate, I currently have 1.5 litre header tank but have to run it very low in tank or have to run overflow tank, I have extra capacity over stock, I'm presuming stock hold more than 1.5 litres
Old Apr 1, 2023 | 09:00 PM
Mark V8's Avatar
Mark V8
Don't know the capacity as never filled it!
It's 35mm taller than a standard tank just to get the air bleed to work.
Edit to add the old fashioned cap gives a little more bonnet clearance and gives the option of using an expansion tank if it overflows
Old Apr 1, 2023 | 09:05 PM
scoooby slayer
Would probably not fit as my inlet is so close to inner wing, custom headertank had to be made by spec r but it looks smaller to me than stock
Old Apr 1, 2023 | 09:11 PM
Mark V8's Avatar
Mark V8
This any help?
Old Apr 1, 2023 | 11:06 PM
scoooby slayer
This any help?
Diamond cheers buddy il have a measure tmrw to see if it will fit
Old Apr 2, 2023 | 02:53 PM
scoooby slayer
This any help?
Won't fit mine mate would hit the inlet, I might just run a 500ml overflow bottle that should do it, I've got makeshift one in now to try make sure it's ok
Old Apr 2, 2023 | 04:29 PM
Mark V8's Avatar
Mark V8
If you get a chance can you have a look to see what was done to protect fuel tank without rear arch liners mate?
Still got that job to sort on mine.
Old Apr 3, 2023 | 09:14 PM
stevieturbo's Avatar
stevieturbo
C**t
If you need room for expansion, then just run a bare minimum of coolant visible in the header. It does not need to be full ! Just run enough so that when cold, you can visually see there is coolant in it so you always have that reference.
I just use an Audi/VW header tank on mine and have zero issues
And if concerned about HG or something, always monitor/log pressure in the cooling system
And an overflow bottle serves the additional purpose of allowing it to eject water, and then if correct cap is used, draw it back in again as it cools. Although I prefer to keep the system running as a closed system without the need to eject and draw back in.
Old Apr 8, 2023 | 07:36 PM
scoooby slayer
No arch liners on mine mate at the back, do you know what total capacity of your oversize header tank is ?
Old Apr 8, 2023 | 08:50 PM
Mark V8's Avatar
Mark V8
I've no idea, sorry.
Only reason I had it made was the fact that the first one had the sight glass centreline lower than the highest water pipe on my engine and wouldn't have got the air out of the system.
AJC
Apr 30, 2010 10:06 PM
cossiemanden
Aug 31, 2007 08:58 PM
