MK4 XR3I EFI Running issue.
Old Mar 2, 2023 | 09:41 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Default MK4 XR3I EFI Running issue.
I have an XR3i, when starting the car it starts turn of the key fine and seems idle right and revs freely in neutral but once i drive off its holding back at times and revs bog down unable to get past 2500rpm.It seems to be happening at around 60mph If i then turn engine off and restart it works as it should, any ideas?
I have replace the follow..
HT leads
Coil pack
plugs
Air temp sensor
Tried a different MAP Sensor and all of above made no difference.
TIA
__________________
RSMK4TURBO
Escort Range
Aug 15, 2023 05:44 PM
brad
Apr 21, 2011 09:16 PM
fastrac28
Oct 24, 2009 09:12 PM
