New built engine compression test results
Old Oct 18, 2022 | 02:15 PM
t3garett's Avatar
t3garett
Default New built engine compression test results
Hi all
I ve just begun my engine running in and everything is fine, no leaks, no smoke, pulls nicely (only using 0.5bar boost and not going over 4000rpm).
decided to do a compression test as a bench mark figure to keep track of the engine's health over its life and I m a bit surprised....
I have a perfect 130psi on each cylinder (no variation between cylinders) bit this figure seems a bit low.... and has got me worried !
engine has stock pocketed pistons, grA Head gasket, refurbed head but only one skim on it and bd14 inlet, std exhaust.
What do you guys think ?
Old Oct 19, 2022 | 08:16 PM
smiley's Avatar
smiley
What does your engine builder/tuner say that's who I'd be asking
Old Oct 19, 2022 | 08:20 PM
t3garett's Avatar
t3garett
Well actually I m my engine builder / tuner and I think my piston pockets and grA headgasket have lowered my compression ratio slightly more than alticipated.
but the engine works perfectly (no smoke, no misfires and pulls fine) so I m reassured
Old Oct 20, 2022 | 04:46 PM
t3garett's Avatar
t3garett
I suppose I really wanted to know if anyone knows the figures of what their stock compression test values are or even better what their pocketed piston values are.
anyhow I ve just done 200km of run in and the engine is doing great, leak down test is fine, no smoke no nothing really so I consider myself sorted.
Old Oct 21, 2022 | 11:04 AM
cossynut2's Avatar
cossynut2
10 Year Member
If the engine is now run in you need to get it on boost to see how it performs on the open road.
Old Oct 25, 2022 | 06:06 PM
Mark V8's Avatar
Mark V8
I'm pretty sure my old 4x4 Cosworth was 150psi on first oversize standard pistons
Old Oct 25, 2022 | 07:28 PM
t3garett's Avatar
t3garett
Cheers, thanks for that.
I did ŕ leak down test and have under 10% leakage from each cylinder so I know now that my engine build is perfect and my rings are definatly seated ok. So my 130psi compression figure is definatly coming from my piston posckets and headgasket.
The engine is perfect at the moment (only done 350km run in ) I ll report back when I can finally put my foot down and see what it s like with réal boost (I ll probably break the gearbox &#129315
Old Oct 25, 2022 | 08:20 PM
Mark V8's Avatar
Mark V8
Different cam timing can also make a difference, didn't notice that you had a bd14 cam!
If there's more overlap than standard the cranking compression will be less...
Old Oct 25, 2022 | 08:21 PM
t3garett's Avatar
t3garett
Yes I m taking that into account as well. Thanks for the help !
Old Oct 26, 2022 | 09:36 AM
cossynut2's Avatar
cossynut2
10 Year Member
I reckon the compression ratio will be about 7.5 to 1 which is the same as my 2wd Saff and is now thought of the "old school" way of tuning. Nothing wrong with that as with other modifications you could easily be over 400bhp!
Old Oct 26, 2022 | 05:20 PM
t3garett's Avatar
t3garett
Thanks for the info. Yes I think I ll be hitting the 400bhp mark.I m running rplab programmable ecu with greys and t36 turbotechnics and all the other mods to follow including chassis and brakes.
kurdt5
17
Apr 26, 2013 10:49 PM
55rsturbo
Feb 12, 2012 04:01 PM
Lee Ivatt
Aug 19, 2008 06:30 PM
_DAN_
Technical essay Archives
Apr 27, 2006 02:29 PM
Chris69
Mar 5, 2006 07:21 PM
