Fiesta 1.3 to sportka 1.6 engine swap
Old Jul 16, 2022 | 09:16 AM
HubbDk's Avatar
HubbDk
Default Fiesta 1.3 to sportka 1.6 engine swap
Hello, as the title says I want to swap my boring 69 hrsprs 1.3 rocam engine that comes in my 04 fiesta with the 1.6 rocam from a sportka/streetka wich makes a whaping 95 hrsprs, and i need some advice regarding the folowing.
I know that :
  • they are the sane engine, just diffrent bore size
  • one uses a diffrent type of injectors and I might think fuel pump
  • bothe use iac valve and a DBW throtthe body
Now, my questions would be:
  1. Can I just swap the engines without changing to the 1.6 ecu ?
  2. If i swap the ecu, wich looks the same as my ecu, will i retain all the functions that my car had before ?
  3. Can i use the gearbox from the 1.6 ?
  4. If i use the gearbox what axles do i need ?
Thank you in advance guys for the answers and the help.
CapnJack
Jun 29, 2022 06:47 AM
Painfulagenda
Mar 5, 2017 07:09 PM
Nickyyy
May 25, 2010 04:02 PM
Fociwill
Ford Focus RS
Jan 28, 2010 03:14 PM
escort1995crusier
Nov 28, 2008 09:56 AM
