will an xr2i gearbox fit an S2 RS turbo ?
hi all
Does anyone know if the box off a cvh XR2i 1991 will fit an S2 rs turbo ? Mine needs a rebuild and they're quoting up to 8 weeks but I have a 2i engine and box in the unot and was wondering if it would work so I could keep using the car whilst the rst box is being reconditioned
Any ideas please
Thanks
Any ideas please
Thanks
hi all
Any ideas please
Thanks
Any ideas please
Thanks
But: Depending on when your car was built (pre August 86 cars with push down reverse) you might face some stiff gearchange. With a later MK4 Escort everything will be fine. Speedo drive might be different, you should just swap it to be on the safe side.
RetroTed
Jun 25, 2022 10:20 AM
Marconi1982
Aug 8, 2017 08:33 PM
