General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
As you are aware trying to find OE A pillar seals for the Sapphire Cosworth is virtually impossible so there are a couple of places now selling new replacement ones. What are your thoughts on them? I have tried 2 lots and I found neither of them much good.They are to flimsy and just do not fit and seal properly.I have now repaired my original Ford ones and they will be going back on . When you compare them the original Ford ones had a metal extrusion with the rubber and felt attached and are very solid and also shaped to follow the contours of the bodywork. I did'nt want to name the suppliers in case others have fitted them with success. My original ones ready to go back on One of the new ones, already out of shape Squashed out of shape The seal sticks out and has gone out of shape.
Hi Glenn, I do remember seeing them myself but a piss taking price!! I have cleaned up my original ones and repaired the damage so they will be going back on. If a supplier actually looks at the original ones and comes up with a replacement made in the same way it would be good but I guess it's all about low volume cost.
Hi Mark , I tried 2 different sets which are supposed to be a replacement but very disappointed with the quality and poor fit.I am convinced the people who make these parts never actually try to fit them on a Saff as they would see straight away they do not fit properly!!
The places who are doing stuff havent even ever seen a real one thats the problem.. its like most things now 3d printed center caps thst dont fit. the escort cosworth weather stripes. rear spoiler gaskets just all junk tbh... I would just keep lookn for a better set then yours mate you will find some one day in mean time just tidy yours up
you can get door rub strips there Ł350 a set there mint spot on... its the door window trims there s%%t look horrible.. i may look into it see what can be done etc
See to me 350 quid is still dear. I would happily pay 200 quid.
sadly thats why stuff is shite these days... because people want everything for nothing but if there sold there cars there will expect top money for them hence the sapphires like 25k with scabs all over roof and arches ..
Are you talking about the A pillar seals like the ones in my post Lee? I have not come across any yet that are any good.
Hi mate. no i was on about the door molding sets for Ł350. and the window weather strip sets u can get from east kent trim place... ive seen few of them trims your after aftermarket kind but none look any good in photos.. id hold out for a set if i was you rather then wasten money on junk..
I have cleaned up and repaired my original ones and put them back on the car. They are much better than the so called new replacements which are just a waste of money.
Has anyone cut and pasted those outer weather strips for the doors as in where they usually bubble and split on the ends. Where it is straight use cut from another used one as a donor and cut the straight bit off and flush and use that part. On modern cars its not one piece but many. Just wandering how it would look and function?
Found my replacement B post seals out. There terrible, Im surprised I didnt check them.
Had these from a place called Classic Car Seals on ebay. There not listing anything now so dout there about still as I've had them over a year.
I think this one image says it all, non of the holes line up and they definitely need the metal inserts to shape them.
Hi Mark, they look similar to the ones I bought, total waste of money, way to flimsy and as you say the holes are not in the right places. My old original ones made by Ford are so much better and after a good clean and some repair are back on my car.
Hi Richard, I've repaired my original ones now after seeing this.......a good clean, a very small amount of glue to hold the loose parts in place then a thin bead of black silo on the rear pressed through to fill the voids. A careful wipe down and they look ok.
