Help! Ford Sierra front wheel bearing pressed or not?
Old Apr 1, 2022 | 04:36 PM
Cossie_dean's Avatar
Cossie_dean
Default Help! Ford Sierra front wheel bearing pressed or not?
Does anyone know if the Ford Sierra front wheel bearing is press in type? Thanks in advance. Dean.
Old Apr 1, 2022 | 07:02 PM
BIG LEE's Avatar
BIG LEE
you got the white rs500 copy?
Old Apr 1, 2022 | 07:04 PM
Cossie_dean
Yeah mate that's me 👍
Old Apr 1, 2022 | 07:12 PM
BIG LEE's Avatar
BIG LEE
You may remember me i bought some mk5 escort bits off you etc.. Then for some reasion we had a bit of an issue over a jaguar s type you were selling when i turned up at address and car was sold?..
Anyways them bearings are race type you can knock them out with drift weather there cosworth hubs or std sierra both the same... when you fit new ones when u nip it up if it goes tight its the wrong bearing mind as the nut is suppose to be daft tight and stay free.. what make bearing you fitting?
Old Apr 1, 2022 | 07:19 PM
Cossie_dean
Ah aye I remember you bought some bits off that mk5 cossie replica.. Spot on mate, the make of the bearings I think is napa summit like that.the measurements are 35,60,18.5mm. Cheers.
Old Apr 1, 2022 | 07:29 PM
BIG LEE's Avatar
BIG LEE
Ok well if you get stuck giz a message etc.. ive not used that brand of bearing before i use FAG or SKF myself never had a bother with them etc
Old Apr 1, 2022 | 07:31 PM
Cossie_dean
Nice one mate cheers 👍
Old Apr 1, 2022 | 07:40 PM
BIG LEE's Avatar
BIG LEE
No trouble.. you still just got your 3door like?
Old Apr 1, 2022 | 07:43 PM
Cossie_dean
Yeah still got it, just busy sorting all the bits that's been doing my head in ready for the summer etc.
Old Apr 1, 2022 | 07:45 PM
BIG LEE's Avatar
BIG LEE
best way like.. ill probs see you about at the local shows like 👍
Old Apr 1, 2022 | 07:47 PM
Cossie_dean
Aye definitely mate I'm always at them like 👍
adam151082
Nov 28, 2014 08:13 AM
steerfromdarear
Jan 29, 2014 08:26 PM
ram
Jan 8, 2014 11:51 AM
RS_Cosworth330
Ford Escort RS Cosworth
Apr 24, 2006 02:21 PM
