abs accumulator
Old Mar 13, 2022 | 03:46 PM
lime's Avatar
lime
Default abs accumulator
Hey guys has anyone every used an accumulator from another vehicle to replace the accumulator on the Cosworth's unit, I have been looking at the Land Rover p38 they look similar only difference I can see is the p38's pressure rating is at 200 bar, hopefully some one can shed some light on this
Old Mar 16, 2022 | 01:54 PM
Zigu's Avatar
Zigu
10 Year Member
Hello, I`m also interested about this. If thinking technically how this accumulator works it might be possible to use some other one also, because:
-the ABS accumulator is a storage device in which the hydraulic pressure that is required for the brake's hold-release-reapply cycle is stored.
-pressure switch shall stop ABS pump, when correct pressure is reached, so break fluid pressure will be exactly same, even different accumulator is used
So, if new accumulator pressure rating is higher or same comparing to original one, I don`t see any reasons, why it can`t be used.
Here is also picture, how bad accumulator can be tested:
1. use some not sharp edged stick or similar tool to check how deep it goes
Old Mar 16, 2022 | 05:37 PM
james kiely's Avatar
james kiely
I seem to remember that the p38 can be used
Old Mar 17, 2022 | 12:43 AM
lime's Avatar
lime
hey this is really helpful and informative, is their a way to recharge the nitrogen in the accumulator .
Old Mar 17, 2022 | 06:25 AM
Zigu's Avatar
Zigu
10 Year Member
There is reason, if nitrogen has got way out from the accumulator and recharging doesn`t fix that problem.
Old Mar 20, 2022 | 11:11 PM
lime's Avatar
lime
hey guys the accumulator was F*&Ked had a spare which is working .
Old Dec 19, 2022 | 09:14 AM
RalphLopez's Avatar
RalphLopez
Thanks for the pic. If you require translation services but are unable to locate a reliable website for them, I can help. You can find assistance with translations at; you can read more about it see here. This website offers quality translation services, therefore I could utilize it to translate some of my own documents.
RobertM
Mar 20, 2016 07:27 PM
mark needs help
May 20, 2012 09:29 AM
c.fogarty
Jun 8, 2006 08:55 PM
THE RADMAN
Ford Escort RS Cosworth
11
Apr 26, 2006 04:04 PM
jellyRS
Dec 26, 2004 06:23 PM
